メインコンテンツにスキップ
2018年7月に発売された15インチMacBook Proです。モデル番号はA1989です。15.4インチ LED-Backlightディスプレイ、True Toneテクノロジ、TouchIDと最大6 Core i9プロセッサを搭載しています。
20回答 すべてを表示
Ram upgrade 2018 touchbar MacBook Pro 15
I would like to get a video on to how to open my 2018 Touch Bar MacBook Pro 15”, I have bought it with 16 GB of RAM and have bought the 32 GB RAM cards would like a walkthrough please…
As for some weird reason I could not get the base cover to unhinge as easily as my MacBook Pro 2015-2016 retina model
Have been worried of breaking a chord or something if I could get some guidance…
You can even upgrade the RAM firstly? And if so a step by step guide would be amazing…
YouTube has no videos about it as yet BTW so you could be the first to break it!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
IFIXIT has a teardown which you can watch here: MacBook Pro 15インチ Touch Bar 2018の分解
さんによる
コメントを追加
5件の回答
ベストアンサー
You can’t upgrade the ram, ram hasn’t been upgradable on MacBook Pros since 2012. At this point you have no reason to be opening that computer, as you will be voiding your warranty on a brand new product, and there really isn’t anything you can do inside anyways.
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
Opening the computer will not void a warranty. Companies stating this are actually breaking the law.
さんによる
ryanantovel - Be careful here! Different countries have different laws! While that's true in the US, others maybe very different.
さんによる
コメントを追加
最も参考になった回答
All Touch Bar models have ZERO upgradability , not the RAM, not the SSD, no nothing.
このアンサーは役に立ちましたか?
スコア 8
1件のコメント:
Fast approaching throw-away 2k/3k laptops!
さんによる
コメントを追加
If you have the correct RAM with BGA, circuit layout and find the particular resistor on logic board, maybe you can upgrade it.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Hello,
I read that welded is like, impossible to move.
Did anybody unweld RAM from motherboard to weld a larger one on it with a 10$ soldering iron?
Thank
さんによる
The scale of shrinkage in micro-electronics has eclipsed our ability to fix them with the tools we once used as well as the skills.
Here you need a very expensive desoldering & soldering stations and the skills to use them and the other special tools.
Think of it this way do you want the plumber who fixes your toilet to fix the bleeder in your brain? Clearly the tools the plumber has won't work fixing the leaking blood vessel in your brain, yet alone the skills!
さんによる
コメントを追加
the ram is solderd in place.
sorry
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
its solderd in place
さんによる
コメントを追加
There is a way to do that… but you need to be very skilled.
https://www.youtube.com/watch?v=X3diHEOo...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
seth1605 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 23
過去 30 日: 62
今までの合計 32,875
