メインコンテンツにスキップ
ジャンプ・ドライブ、USBスティック、サムドライブとしても知られるUSBフラッシュドライブの修理ガイドとサポート。
50回答 すべてを表示
My flash getting hot,when ı plug into my laptop.
I have SanDisk ixpand 32 GB (2 years old) and a brand new SanDisk Ultra Fit 3.0 32 GB USB thumb flash drives.
My problem is, both flash drives are always getting hot when I plug them in and do any file transfer.
  • What can I do to prevent them from overheating ?
  • Is this harmful to them ?
Thanks,
Regards.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Heavy file transfers will cause the drive to get warm. This is normal.
さんによる
SanDisk flash drives are widely copied. Only the fakes get really hot! A genuine drive just gets warm to the touch, after read/writing.
さんによる
コメントを追加
5件の回答
ベストアンサー
It is normal for a flash drive to get warm duing use. (my sandisk cruizer blade gets quite warm when moving files from it)
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
maybe his computer is very hot itself, you know
さんによる
No I had Omen and enough cool .
さんによる
SanDisk flash drives are widely copied. Packaging and the products appear 100% genuine, but only the fakes get REALLY hot. It's really difficult finding an on-line store that sells the real item!
さんによる
コメントを追加
Run Task Manager to see if there is a lot of drive activity with regard to the USB drives.  (A lot of continual drive activity could cause heat.)  If there isn’t, then the USB port is likely putting out too much power.  I don’t know how that could happen, unless there is a chip in the computer which is bad and which controls power output.
If there is more than one USB port, does the problem happen when you plug the flash drives into a different USB port?
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I will try it but i connect my ixpant to my iphone and same happens .
Thanks,
Best Regards.
さんによる
コメントを追加
Good flash drives will throttle their transfer speeds down to accomodate for heat output from the flash drive itself. Nothing to worry about. I have plenty of flash drives that do this due to heavy file transfers and they are still working till this day so it’s normal.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Poor design factor. Doesn't matter what computer I use the Sandisk Ultra Fit in, it always ejects *HOT*!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Ultra Fit 3.1. Just bought new. Original product, not fake, as proven by the PrivateAccess software. Just plugged. No transfer. After about 5 minutes, so hot. Not warm - hot.
For anyone who says only fakes get hot. Please only share information you can back up.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Carun さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 45
過去 30 日: 145
今までの合計 19,886
