Removing the iSight / FaceTime camera from a MacBook Air
Hi All,
I have been trying to find out information regarding removal of the iSight camera from a MacBook Air.
I am looking to remove the camera so that I can take it to work as I am often working in areas where cameras are restricted
As far as I've been told its also not possible to remove the camera from any of the macbook pros due to the glass screen, hence why a Macbook Air becomes the next option.
I am aware that it is possible to remove the camera from the body, removing the front panel and the unscrewing the camera mounding and cutting the wires? Or that you can get software etc to disable the camera (however, I am looking for a permeant removal)
However, will physically removing the camera cause any software issues with the laptop? Such as, starting up the machine, could there be issues with devices not being found and then causing startup issues?
Or another potential issue could be regarding future software updates, with software updates to the camera, which once removes and wires cut out, then could cause conflict issues with updates?
Or if you fully disconnect the camera will everything just work as per normal?
Also I fully understand that it will void any Apple warranty which is understandable when accessing or modifying the machine.
Any Ideas on this issue will be very much appreciated
Thanks
Tom
