メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
773回答 すべてを表示
Thunderbolt port not working
There is a loose metal tab which is preventing any thunderbolt device from connecting properly.
This appears to be an assembly issue as all I've done is use external hard drives or tethered cameras. I'm being quoted £600 to replace the logic board which is outrageous.
Is there a a cheaper fix?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
最も参考になった回答
What happened is a cable was inserted which for some reason snagged the connectors contact (which is what you are seeing). So basically the connector is broken ;-{
Now the fun part replacing the connector! As it turns out the connectors are fastened onto the main logic board. Here you can see them:
Here is the back side of the board
It’s a lot of work to get these off and you can’t buy them as they are a custom part. Which is why you end up needing to replace the complete logic board.
I would go to a Apple Store and have them do it as you should be able to ask for the bench fee (flat rate) plus parts costs which should be the cheapest you can go.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Thank you for being so thorough. Is it something I can pull out with tweezers? Or push back in?
さんによる
Also whats a bench fee?
さんによる
What happens when you bend a paperclip too many times?
These contacts are more likely to snap if you try and even if you are so lucky the contact won't have the needed springiness to mate up with the cable end reliably.
さんによる
@danj "Flat Rate Repair" $357 for new board installed
さんによる
コメントを追加
I realize this is an old post, but if you still have this laptop and still haven’t found a fix (or someone else has this issue):
From your photo, it appears that the bent metal tab isn’t one of the contacts from the connector. It appears to be part of the surrounding frame for the port that got bent down towards the connectors contacts. (It may be the ground contact that needs to touch the outside of the thunderbolt cable’s connector.) It appears to be short circuiting with the contacts in the center of the connector. I would try bending it up and trying to get it flush with the upper inside surface of the opening.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I also realise that this is an old comment to your post,
just like to say thank you as you've solved my problems
both my ports were not working, so i thought.....
it was the bent metal tab as you described above preventing them to from connecting correctly,
good man yourself
thank yo thank you thank you
Tony
さんによる
I know this is an old post/comment but this also saved me. carefully bending up the metal tabs and using a paper shim to get the connector inserted without rebending the metal tab indeed got my thunderbolt connector working again. properly fixing the connector so I can just plug/unplug may be impossible. probably have to take the whole logic board out and take a look at the backside.
さんによる
コメントを追加
Check this video on youtube it will be helpful to tighten your port https://www.youtube.com/watch?v=B_ruqSrk...
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Hi. Thanks but the pin has dropped down completely.
さんによる
@amily - Sorry this is a very different connector! The person in the vid is adding a bit of tension on the grounding clip which is a very beefy spring so you could give it a bit of a bend. The Thunderbolt contact here is not the same, and besides its not a looseness issue it's a mangled contact issue.
さんによる
@danj Yes the connector is different but it can be replaced as shown in video
さんによる
The video shows someone bending the grounding clips up. He is not replacing.
The MacBook Pro's have the connectors either soldered directly to the logic board or in some models some of the connectors are soldered to a daughter board.
Even still I don't even try to salvage from junkers any of the ports as its just too hard to pull out without damaging them or the logic board.
さんによる
コメントを追加
I have a 2015 MBP with thunderbolt 2 ports. Yes I know it is EOL but it is the last one with the keyboard I love.
Had it into Apple in December 2023 for an old battery recall. They had to do it twice in one week because the first replacement had a bad keyboard in the topcase assembly. Then I had to go in a third time in January because they didn't calibrate the keyboard correctly (function keys didn't work correctly).
Anyway I almost always run the laptop in docked mode (thunderbolt dock) at my desk and work from home.
Recently I had to travel a bit and so was plugging and unplugging the thunderbolt a bit more. First one port stopped working (noticed connector felt loose around same time) and then the second port failed within a few days after I switched to using it.
When I inspected the connectors, I didn't realize those metal tabs were in the wrong spot, but Nunio's comment is spot on. Why did both connectors fail in a short period of time after all these years? Looks like apple boned me again.
Apparently when they gutted the laptop to replace the top case, they didn't properly install the logic board, or the new topcase mounts are a little off. You can see in the attached image that the headphone jack is "too low" and not properly aligned. It is the same inside the thunderbolt ports. That top metal flange hangs down inside the connector opening in the top case...and that is why the cable snagged and destroyed these connectors after all these years.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
katebones さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 27
今までの合計 4,226
