メインコンテンツにスキップ
モデルA1369、1.6、1.7または1.8 GHzプロセッサー、64、128、または256GBフラッシュドライブ
328回答 すべてを表示
Swollen motherboard after using heat gun
Hi there,
I used a heat gun to replace the backlight IC on my Macbook Air.
I must have heated it too long or too strong, because at one point, the motherboard underneath started swelling. In total the "bubble" reached maybe 1 inch in diameter or so.
It quickly fell back, but everytime I would heat it again it would swell again.
The problem is that now, some connections are not happening. When I use my multimeter to test for continuity, at some point continuity is not there unless I press really hard on the board with my probe.
Is there a way I could fix that ? Has anyone encountered this before ?
The only idea I could come up with so far was to drill a hole, and use a bolt to compress the board. But I am afraid I will be drilling through a wire by doing so.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
John Dupont "The only idea I could come up with so far was to drill a hole, and use a bolt to compress the board. But I am afraid I will be drilling through a wire by doing so" not going to work you have a multilayer board and you most certainly ruined the traces within the board itself. There is no fixing it!
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Ok thanks for your answer !
さんによる
コメントを追加
El cheapo heat guns can and will destroy a logic board by overheating. Sadly your logic board is gone. You’ll need to get a new one.
What you need is a proper rework station to do it right. These have temp & air flow controls to prevent this from happening.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
John Dupont さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 168
