メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
AC randomly turning off
So I have a 2007 Corolla. Sometimes when I start the car the AC won't turn on. None of the speeds work. Then randomly while driving, it will kick in and work for a while.
The first time it happened, it was only for a short time, and didn't happen again for a while, but now the 'outages' are getting a little closer together. I don't know if there seems to be a short in the wiring or something? Any help would be appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
This sounds like a bad ground . Finding the end of the ground wire can be a task . It is often easiest to just run a jumper off the ground wire at the blower and make a new ground on the firewall with a self taping screw . Hope this helps
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I have the same problem,
I have three cars for me, my wife and my son.
I used to take them to a mechanic, and he always created more problems than he fixed.
Suddenly, all three cars experience the same issue: the AC works intermittently and stops working at times. The Corol car heats up if I turn the AC on, but the coolant fluid is normal
Where can I find the ground wire, or where should I begin my search?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Andrew Fisher さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 20
今までの合計 667
