メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5もしくは3.8 GHz Core i5もしくは4.2 GHz Core i7 Kaby Lakeプロセッサ (ID iMac18,3) / Retina 5Kディスプレイ。システムは類似しているため、修理ガイドについては旧モデルのiMac Intel 27インチ Retina 5Kディスプレイ (Late 2014 & 2015) を参照してください。
CPU Upgrade to 8th Gen Intel
Hello Guys!
Last year I bought a base model iMac 5K and it was working fine for me but my work has intensify and I would like to upgrade the CPU to an i7 and the HDD to and SSD .
My question is: Now that Apple lunched the Eight Gen CPU's in the new Macbook Pro. Can I opt for the 8700K(or any variant of it) instead of the 7700K?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
ベストアンサー
Sorry not an option in your system the rest of the systems logic would need to be swapped out as well (which is not practical) your system is based on Kaby Lake the new 8th gen is using Coffee Lake architecture while similar it’s not drop in compatible.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
hi Alex Castro your imac only upgare to high cpu but only same life and socket
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This is possible,It has been done on motherboards from third party vendors, apples logic is no different, What is needed is a patch for the bootloader, or a spoof in the efi and the compatibility fix added to it that was done with z170 motherboards.Whoever does it first will get a ton of rep.For now though if you can get a 7700k, you wont be disappointing, And I wouldn’t hold your breath on anyone in the mac community putting as much trial & error and time into this.(Just saw that its quite a few months old, didnt mean to revive the dead thread).I also swapped in a 7700k from an i5, tricky but rewarding.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes its easy on a Windows PC, Mac's are a very different beast! Its just not that easy. Unless you've got the skills to dig deep into the firmware its just not possible!
さんによる
コメントを追加
回答を追加する
Alex Castro さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 3,797
