メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPad 2と同時にリリースされたSmart Coverは、スタンドにもなるスクリーンプロテクターです。Smart Coverは第2世代と第3世代のiPadの両方で使用できます。
How is the fabric sealed?
I'm just wondering how both fabric sides are sealed together to encase the plastic / metal strips - I'm assuming it's just glued. Is there any stitching involved? Do you think it would be possible to take apart the Smart Cover and replace the fabric with some of my own?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
According to iFixit's teardown of the Smart Cover, it doesn't seem feasible to attempt doing so. The design does not lend to being modified by any means and will likely destroy the Smart Cover should you try.
I'm not saying don't do it...I'm just saying that if you do:
1) Take the proper precautions against flying parts (see teardown).
2) Document what you do, with pictures, so you can post a guide here for others to reference.
3) Make sure you are willing to part with a perfectly functional Smart Cover to do this (or at least have the funds to replace it).
While the inquiry isn't strictly repair-related, I can see its utility in case a Smart Cover ends up damaged in some way (acid spill, cigarette burns, etc).
I hope this helps in some way...tho I'm sure it's not quite what you were hoping to hear.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Andy McDonald さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 3,619
