Is there a generic P5 pentalobe or a special one for MacBook Pro
I need to fix my MacBook Pro 2015 lcd screen. The tutorial on this site lists 5 necessary tools. One of them is a “P5 Pentalobe screwdriver retina MacBook Pro and air”.
I see the following item advertised on iFixit:
“p5 pentalobe screwdriver retina MacBook Pro and air”
Then I also see the:
“Pro tech toolkit” which includes a P5 head.
Are these two screwdrivers the same size? I’d like to buy the “pro tech toolkit” because it appears to include everything I need.
3 件のコメント
i use the same toolkit and the p5 bit works well to repair any macbook. its fit to macbook, macbook pro and some other models.
Ringo Hinze さんによる
Thank you, Ringo. It would be nice if iFixit would be clear on this. If you look at the MacBook Pro 2015 screen repair guide it lists 3 screwdrivers:
”T5 Torx Screwdriver,”
“T8 Torx Screwdriver,” and
“P5 Pentalobe Screwdriver MacBook Pro Retina and Air.”
Then when you visit the page where the screwdriver is sold it does the same thing.
Why not just list it as P5 Pentalobe? Or if this shape is particular to this model of MacBook, it would be nice if the Pro Tech Toolkit would list the bit the same way vs just listing it as “Pentalobe P5”
A. S. さんによる
Sadly, Apple makes this hard, don’t blame IFIXIT!
So to be clear Torx is an industry standard fastener. Now Apple had to create there own fastener! Pentalobe While it looks like a Torx which has six lugs the Pentalobe has five lugs. Just looking at the side It’s hard to tell which is which.
The guides are correct and depending what you are working on you could need even other bits!
Dan さんによる
