Why doesnt my wifi get connected?
Recently my wifi has auto forgotten the wifi and when I try to connect the wifi to the phone again it doesn't work. An error message pops up saying "enable to connect". What should I do? Please help !!
It seems like your wifi antenna in the iPhone isn’t working properly. Try a factory reset, but back up your information first. If that does not work you’ll need to replace the wifi antenna. It’s not a hard process. the part can be found here: https://www.fixez.com/store/iphone/iphon...
The tutorial can be found here: iPhone 6 Wi-Fi アンテナ交換
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 30
2 件のコメント
Does it work on other wifi ?
Blanco さんによる
Can you enable wifi or the setting itself is greyed out ?
arbaman さんによる
