メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
774回答 すべてを表示
Why is my display not working?
About six months ago, I splilled water on my MacBook. I took out the logic board and cleaned it. Everything worked properly. I decided to clean the logic board again when I installed a new trackpad cable a few days ago. Upon reinstalling, the display doesn't work. I am able to use the computer fine with an external monitor. I can't figure out if it's a problem with the display socket on the logic board or if I should purchase a new replacement display.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
It's impossible to answer your question without testing the logic board, or trying installing a known good screen. Given the history of your Mac I'd be more inclined to think about a logic board failure. Lvds connector and lcd enable circuit would be the first to check in my opinion.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Take a flashlight and shine it through the Apple Logo. Are you able to see your desktop icon’s? If you do then your issue is within the backlight circuit. It could be as simple as a burnt fuse link or needing a new driver chip.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sam Quinn さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 5
今までの合計 107
