メインコンテンツにスキップ
Google PixelはGoogleから発売された最初のスマートフォンで、2016年10月26日に発売されました。5インチのAMOLEDディスプレイを搭載したこのデバイスには32GBもしくは128GBのオプションがあり、 ベリーシルバー(Very Silver)、クワイトブラック(Quite Black)とリアリーブルー(Really Blue)から選べます。
LCD Display unresponsive black screen issue
Ok, so one day I decided to tear down my google pixel so I can change the battery (It needed to be done). While taking out the top portion of the screen, I had dug in far too much and cracked the LCD screen in several points. Knowing the potential harm I have already done, I proceeded to go to the battery just so I can attempt to finish the task I had at hand. After reassembling the phone (surprisingly) it didn't display any type of information, or show any signs of touch response. What I did notice is that the power button and the finger scanner on the back have responded well. To get to my question, I wanted to ask if the issue I am dealing with is solely an LCD replacement issue or did I screw up my phone to the point where I need repairs out the wazoo?? I'll appreciate any feedback!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
You will need to replace the screen assembly. When the inner layer (LCD display layer) gets cracked the phone will not display any image which is unfortunately how OLED displays are.
Looks like the only issue is just the screen as you can tell the phone is on.
Here is guide and parts from iFixit it needed:
Google Pixelディスプレイの交換
Google Pixel Screen
Google Pixel Display Adhesive
For future reference and to help others when you want to remove glued in screens like the Pixel / Moto only pry in as much as the width of the adhesive for where you are prying and avoid flexing the glass / screen assembly as that is how lots of them get damaged.
A good guide is looking at YouTube videos of people opening up these phones. That way you know exactly how much you can pry in without needing to pry / push into the LCD.
Thin plastic flexible cards, heating the screen (80°C) and isopropyl alcohol on the card is the best way to lift up adhered screens.
Replace a screen compatible with Google Pixel 1st Generation model smartphones. 5.0 inch AMOLED 1180 × 1920 display and front glass digitizer.の画像
製品
Google Pixel Screen
$59.99
This custom cut adhesive film secures the front glass digitizer screen to the midframe assembly of the Google Pixel.の画像
製品
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
回答を追加する
Michael Radwanski さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 1,491
