メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Monitor not displaying correctly.
Just picked up a 31.5 inch monitor from AOC, the Q3279VWF to be exact and there's something up with the display. It only comes on when the monitor has force being applied downward on it. For example, if I have the monitor at a 90 degree straight vertical angle, the display may flicker on and off but will remain off mostly, though if I apply light pressure to the bottom bezel of the monitor, it comes on for as long as I hold it.
Sounds to me like a lose connection or something. I'm routing the audio out through the headphone jack and even when the display goes, the audio stays, so it's not the cable. Also when the display goes, the backlight stays, so It's not that.
Any suggestions would be much appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
ベストアンサー
Yeah, I'd agree with Dan's answer but since it was so new I just brought it back and got a replacement, thanks anyway guys!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
There is a ribbon cable located at the bottom of the monitor that may have come loose. I can't say that I have seen this in the past however. More likely, the solder connections for the connector have degraded a bit and require a re-flow. If you can solder, you should be able to resolve this by yourself. Carefully open up the unit (unplugged of course...) and look at both the ribbon cable and perhaps re-seat it as well as the solder connections for the connector itself.
Let us know what you find.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
HI I have tried a few things gently there are 3 screws on the undeside of the bezel but it doesnt want to move any ideas please cheers
Lennie
さんによる 共有
sorry thats for removing the back
さんによる 共有
コメントを追加
Hi,
You say that you “Just picked up a 31.5 inch monitor from AOC”.
The reviews for the monitor indicate that this is a fairly new monitor.
I suggest that you consult the manufacturer’s warranty statement (usually found in the User Guide) as to what to do to make a claim for a manufacturer’s warranty repair or replacement.
It appears that AOC have a 3 year warranty on their monitors. (hopefully in your location as well)
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Evan McConnell さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 61
今までの合計 6,529
