メインコンテンツにスキップ
2011年後期モデル番号A1278 / 2.4 GHz i5 or 2.8 GHz i7 プロセッサー
591回答 すべてを表示
Runnig slow on battery support
The MacBook Pro I have, gets very slow when running on battery, the cursor gets really slow.
So I’ve been reading a lot and I identified my model (MacBook8,1)
I erased the plist file in the kext file that the tutorial shows.
Then when I reset the system it gets better, so I believe that I’ve fixed the problem,
BUT, when I run Serato DJ 2.0.3 off of battery power the processor gets very high processing, and with the MagSafe connector plugged in it gets down to OK.
What can I do??
I also run the app Dan said coconutBattery and shows this:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
First I would check the battery to see how much life is left in it. Download this great free app: CoconutBattery. Paste a screenshot of the main window so we can see it here iFixitでの質問に画像を追加する方法
I would also check the energy settings within the Energy Saver control panel to make sure the settings are correct. I would enable the show battery status in menu bar setting I would also make sure not to put the disk into sleep mode when on battery given you’re running a DJ app here. I hope you’ve got plenty of son de Cuba (Buena Vista Social Club) I love Ibrahim Ferrer’s Nuestra Ultima Cita for us older folks!
Being in Cuba it can get quite hot and humid ;-} So you may need to clean out the dust buildup inside and the fan & heat sink. You may need to also clean and apply a fresh coat of thermal paste on the heatsink. As I’m also suspecting your system may be slowing down as it’s overheating.
Here’s the IFIXIT guide you’ll need to follow: MacBook Pro 13" Unibody Late 2011のヒートシンクの交換 here we are only cleaning it.
You might want to download this app: TG Pro it will allow you to monitor your systems temps so when the system slows down you can see if it’s overheating.
MacBook Pro 13" Unibody Late 2011 ヒートシンクの画像
ガイド
難易度:
中レベル
45 minutes - 1 hour
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
No, no soy cubano, ¡me encanta la música!
さんによる
Thank you Dan, I will download the apps. I already make a clean up of the MBP and replaced the thermal paste. I love music too, but I´m not the Dj, it´s a friend of mine and the MBP is his. I´ll post the photos once I download the app, the Internet in Cuba sometimes is very slow. Thank You!
さんによる
The coconutBattery App shows status Good
さんによる
Can you paste a screenshot of the main window so I can see the other data. As the cycles and the voltages are what we need to focus on.
さんによる
could this be a problem in the SMC chip??????????????
さんによる
1以上のコメントを表示
コメントを追加
First Try resetting the SMC, If this doesn't work then I would suggest replacing the battery. Just make sure not to buy a cheap battery off of eBay; I would recommend the cheapest battery being $40.
I replaced my old battery with this one from Amazon.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Luis Anniel さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 107
