メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone loops apple logo after battery replacement
hello i just bought a replacement battery because my old battery didnt last at all. so i bought your kit for it and watched a video on how to install it and i got it installed perfectly an everything worked, i put it back together and it turned on. it was at %50 and it eventualy died then when i went to charge it , all i got was the apple logo staying on for about 5 seconds. so i tried putting it into recovery mode but as soon as i unpluged it from the wall 3 seconds later the screen went black. so i retried and retried , im not seing a low power icon its just the apple logo repeting and repeating. so i opened it up again and reset the battery plug, and still kept repeating. i tried following this tutorial here ----Flashing white screen after battery replacement
but to no avail. they said it was a seating issue . which in my case it wasnt because it was working fine before it died, they also said if that didnt work it was a faulty battery
any help would be greatly appreciated thx
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
It sounds like a faulty battery to me. You should contact iFixit directly (not the answer forum) and tell them to send you another.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
would i have to pay for another one?
さんによる
and also how do i contact them.......thanks troy
さんによる
ONE MORE THING and the battery was working so i dont understand why would it be faulty if it was in fact working
さんによる
I don't know if you would have to pay for another one. I would assume not since the one they sent you didn't work, where the old battery did boot up. Here is a page I found where you can contact iFixit to see about a warranty swap: https://help.ifixit.com/category/133-con...
The new battery never worked right, only the old one. I think they sent you a bad new battery.
さんによる
コメントを追加
Sounds like either a bad battery, or damage from the disassembly. Hopefully just a bad battery! Quickest way to test is to install the old battery and see how it responds. If it boots up fine, bad battery, if it reacts the same, it is either the new faulty battery or board damage.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
funny thing is that i acidently destroyed the battery sooooooo
さんによる
コメントを追加
回答を追加する
MfreakTV “MfreakTV” さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 75
