メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Googleが設計しHuaweiが製造した第6世代のAndroidスマートフォン。2015年10月発売。
Phone not turning on?
I did a battery replacement, and the phone powered up, but the display wouldn’t come on at all, and I saw the “leaked ink” behind the glass, so I got the digitizer/display assembly, replaced it, put everything back, and now there’s no power at all. Any suggestions on what I might have messed up?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Did you disconnect the battery during the screen replacement process? Need to be careful of Static Discharge, which is something people forget. A small amount of discharge can easily damage the phone.
The other possibility is the LCD/Digitizer may be defective, unless you have another unit to test it on.
Last option is the board, whether there was a shortage or not, if the phone was dropped there is a chance that the boards power system may be at fault. So if you turn on your device and you can hear it, you know the screen works, 100% tested, then power may not be properly distributed.
Good luck, wish the best
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
I get a flashing red light when I hook it up to the charger. I don’t think any static discharge occurred, and I did remove the battery. The phone will not turn on at all.
さんによる
I'm going to try and replace the Daughterboard, maybe that's why it hasn't charged.
さんによる
This is little late, but it was indeed the daughterboard! I took a better look at it, and there was obvious signs of water damage and corrosion.
さんによる
Good Job finding the solution
さんによる
コメントを追加
回答を追加する
Caleab Brown さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 33
今までの合計 956
