メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair guides and support for tablets made by Hipstreet. These tablets run on the Android OS.
Display my tablet on projector screen?
Hi guys,
Need some help.
I want to connect my Hipstreet Hyperion Tablet to a projector (VGA port).
I have purchased a mini USB to VGA converter lead, everything seems to be connected up fine but my projector fails to display my tablet on screen. I basically want to mirror my tablet onto a projector screen.
Please help! Thank you .
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi David,
If the projector is just displaying a black screen, it's possible that your tablet simply doesn't have enough processing and graphics power to send the display over to your projector. I would check to see if your tablet at least has Android 4.4.2 on it. Google states that's the oldest version that will be able to cast its screen. Try connecting it to another source, such as a TV or an old monitor with VGA connectors. If those work and the projector does not, then it could be something with the projector that needs set or isn't compatible with the tablet.
Best of Luck,
Drew.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for this.
When I search on the projector for the source my tablet does no appear at all (VGA 1, no source found).
The android tablet is a 4.4.2.
Head ache but I will keep trying.
Thank you for your help.
さんによる
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 512
