メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Toyota Priusは、Toyotaが設計したハイブリッド電気自動車です。2009年から2015年にかけて販売された第3世代モデルでは、空気抵抗係数を低減した新しいボディデザインが採用されました。
Thermostate replacement 2014 Prius
I replaced my coolant at the dealership for my 2014 Toyota Prius at 50,000 miles . I asked the forum when you replace the thermostat . The answer was when the coolant was replaced , The dealer said they had never replaced a thermostat in a Prius . Their parts department said they had not ordered one either . Thermostats can't last forever . Is the dealer telling me the truth ? Advise ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Thank you for your insightful answer ! Having the history of replacement of the thermostat helps me understand why its not replaced as often in other vehicles I have owned .
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
In the case of a Prius I wouldn't change the thermostat unless the car was overheating. Preventative maintenance is a good thing but in this case I would pass . The thermostat is hard to get to and requires a few hours of labor to replace. As for your statement "Thermostats can't last forever" no not forever but I know of a few vehicles with over 300000 mile that have never had theres changed . The dealer is probably being honest here . Most dealership look for ways to ding you . I would be thankful they didn't say they changed it when they hadn't and then charged you for it . Hope this helps
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
fasteddie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 2,073
