メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
20.2 MPセンサーを搭載した、ソニーのハイエンドコンパクトカメラ、RX100シリーズの初代モデルの修理ガイドとサポート情報です。Sony Cyber-shot DSC-RX100は2012年6月に発売されました。
No power fuse location
My RX100V will not turn on. A shop suggested it could be a fuse. Where is said fuse and where might I find a new one?
Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
5 件のコメント
Did you get this fixed? I believe I have the same problem. Please let me know what you found.
さんによる
I have the same on my Mk V. I dropped it about 3 ft on the grass. Totally dead. Hard to find anyone that will work on it. Tried a couple shops here in Houston. One told me to send it to some place in Vermont. I called them, they want over $400.00 to fix it. Not sure if it is worth it. I went back to using my Panasonic /Lumix. I have dropped that one onto a drive way off the roof, it has a dent butworks like a charm. I put the battery back in it, taped the battery access door shut, no problem. Would love to get my Sony fixed. Let me know if you have your repaired. I appreciate it. Thank you kindly.
さんによる
Gary Griffith
Send me a message directly. I may have an option for you.
Dan
さんによる
@abrsvc Thank you. Any help is greatly appreciated.
さんによる
Gary, please post back here if you find a solution. My Mk. V is still here not working.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
If I recall correctly, all of the "fuses" in this camera are surface mounted fuses. These are about the size of a letter on a quarter. This is not a home owner repair. Some specialized equipment and experience is required for this repair. It will not be popping out a glass fuse and inserting another.
Sorry to bring bad news. The good news though, is that if the fuse is the problem, it is a relatively simple fix once you get to the area. BTW: the fuse should cost no more than $1.00
Dan
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Mike Hamende さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 37
今までの合計 1,904
