メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年4月に発売されたHuawei P9 Liteの修理ガイドとサポート情報。
Huawei P9 lite battery issue
Hello,
I have there Huawei P9 lite. It has been damaged by milk. In Professional store it has been cleaning all the liquid. Motherboard, Touch screen, battery, everything has been tested and works. But there's a little thing that make connection between battery and other stuff that is broken. They tell me it's very cheap but they don't sell this piece anywhere. So if anyone has an idea about what i can do.
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
The problem is that milk is corrosive so it may have damaged the plating on the flex cable connectors. If the flex cables are damaged they can easily be replaced (once you get the case open and can get to them), but if the connectors that the flex cables connect to are damaged then that is a much more expensive fix as these connectors are not replaceable (or sold anywhere that I know of - I suspect that they are either made in-house by the people that manufactured the PCBs or they are made for them & not available on the secondary market). If it is the connectors then you will have to replace the boards that the connectors are mounted to and, depending on the number/type of boards (motherboard, fingerprint sensor, cameras, etc.), it may be cheaper to replace the phone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My battery is draining fast
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Youssef Ben Krid さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 23
今までの合計 393
