メインコンテンツにスキップ
2015年3月に発表され、同年4月に発売されたGalaxy S6はGalaxyラインの中で最高のデバイスです。端にカーブが施されたスクリーンはGalaxy S6 Edgeです。
487回答 すべてを表示
camera black spots in photo
my camera lens was brooked cuz it fall from my pocket however when i am launching back camera i see black spots randomly across the photo i just took .
what is the main cause of this problem and how can i fix it ?
will am i need to change my camera or just the lens cover ?
is s6 edge plus camera fits s6 or not
another question i cant find s6 speaker so if i buy s6 edge would it work on my phone
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Sounds like there's some dirt or something in the lens. Clean it out, if that doesn't fix it then most likely will need a camera replacement.
さんによる
I fixed a similar problem in my Sony Z2 by removing the dust cap nearest the camera lens. This problem was a spec of dust either inside the lens or on the sensor. I then tapped the phone on my work bench. Then I blew into the slot. Turned the phone back on and the spot was gone. PS the lense maybe foggy for a minute or so as a result of the blowing but this quickly cleared.
さんによる
コメントを追加
4件の回答
ベストアンサー
The black spots when using the rear camera is caused by dust going inside the lens. You could try cleaning it out with something like a air compressor but you will be lucky if you are able to clean inside the lens.
You will need to replace the rear camera along with the rear camera glass at the same time to fix that issue.
S6 edge won't work on S6 as far as I know because they are slightly different in size to fit in.
When buying a rear camera make sure it is compatible with your model first.
You can either buy the mid frame which comes with the speaker or just the speaker itself meaning you will need to transfer the new speaker into the midframe.
Personally I would replace the whole midframe to be safe, also make sure that is for your model number of the phone as there are different variants for that too.
Here's iFixit guides if needed:
Samsung Galaxy S6 ミッドフレームアセンブリの交換
Samsung Galaxy S6 リアカメラの交換
Samsung Galaxy S6 ミッドフレームアセンブリの画像
ガイド
難易度:
難しい
30 minutes - 1 hour
Samsung Galaxy S6 リアカメラの画像
ガイド
難易度:
難しい
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Just shake your phone, will help. :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I put my mouth over the lense and blew a few times as hard as possible. Strangely worked and the black mark has gone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had the same problem,
Just take the phone into the bathroom with you and have hot shower, the steam should draw the dust out of the lens.
worked for me
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I have a black dot showing up in my front facing camera photos and videos but if I use a different camera app it doesn't appear. Any ideas???
さんによる
Same problem with me please let me know too if you have resolved this problem
さんによる
Same issue, after phone A50 fell down got this black spot for front camera,
it appears in my photos, videos..etc even on the screen when i am using whatsapp video call but the other person i am talking to does not get it. He sent a snapshot and there where no spot.
さんによる
コメントを追加
回答を追加する
ahmad taha さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 27
過去 30 日: 139
今までの合計 49,880
