メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Googleが設計しHuaweiが製造した第6世代のAndroidスマートフォン。2015年10月発売。
Phone not fast charging
I got a refurbished Nexus 6P a few days ago and it won't fast charge. I've tried with many different fast chargers and cables but none of them work. I think I might just replace the USB as there is some visible use on it. Any other suggestions before I go ahead?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Aidan,
If you have tried multiple fast chargers already I would recommend you to go back to the company you purchased the phone from and ask for a replacement. While it may be at the fault of the USB port, you likely have a small warranty from the seller which would cover this issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Not entirely sure what you mean by it not fast charging? Is it charging too slow? Yes it could be a USB issue but if the battery dies to fast then it may be a battery issue as well.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
It's just how slow it charges. Once it charges it lasts around a day.
さんによる
But did it always charge slow or just recently? Not all phones charge the same. A faster USB connector could fix it like you explained, other than that, just have to deal with it.
さんによる
コメントを追加
You should also be aware that there are several fast charging standards.
Nexus uses USB Power Delivery while most of the devices today are using the Qualcomm Quick Charge standard.
More about the difference here:
https://www.androidauthority.com/usb-pow...
In order to stop wondering which standard you need I recommend you purchasing one of the hybrid chargers which support both. Here is a nice example:
63W LinkOn Car Charger
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Aidan Cheung さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 30
今までの合計 1,123
