メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年10月に発売されたモデルで、モデル番号は20175。
Why does my touchpad not work?
Hello, I am having a lot of trouble with my touchpad. My device is a Lenovo yoga 13 with Windows 10. For some reason, the touchpad does not work. I've looked everywhere online. I've uninstalled and reinstalled touchpad drivers multiple times, restarted my computer, checked the BIOS, and scoured the internet. None of the answers I've found help. my touchpad doesn't appear in device manager, there's no touchpad option in mouse properties, it's like my computer never came with one. USB mice work though. The strangest thing is, it turns on randomly and works for a short period of time. I've looked at the fn control keys and I'm not turning it off. help is greatly appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
HI:
I may be way out in left field but it is possible there is a loose connection to the touch pad.
Has any one opened this device up? have you dropped it ? The touch pad is a separate device on the new laptops and has a separate serial connection to the motherboard apart from the keyboard or could be run in the keyboard connector, (have not had any of your like machine apart).
I have seen a well used unit have the cable squished because of constant pushing or this one fellow kept his paper note pad wedged in that got the thing partially broke from pressure not intended at this area or any other area.
Also as devices go they last longer than the laptop but you may be the unlucky person number 89 with a defective pad.
Yes it should be in the list of connected components because it is a separate device.
So either learn how to take the top off and look at the wiring or order one from e-bay and enjoy replacing it. I would guess a repair shop would charge for your laptop repair worth a big bill. I turn mine off and have a wireless little mouse. Cant stand playing with the touch pad, always resting my palm or fingers on it and away goes email or new browser windows or pointer flying some place while typing.
Just me you know...
Good luck
Alton
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yeah, I decided to just use a mouse. Thanks for the advice though.
さんによる 共有
コメントを追加
Check notification area to see if touchpad has a red X. If so its disabled because of tablet mode. Check to make sure no motion sensors have been disabled, or set to manual [search windows ‘services’.
Sometimes just flicking screen back to tablet mode and back again will wake the touchpad.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ConfuzzledPerson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 29
今までの合計 1,535
