メインコンテンツにスキップ
Standard and high definition handheld video cameras by Sony.
121回答 すべてを表示
DCR-HC21 Flip screen all black
The flip screen on my DCR-HC21 is responding to my touches but isn't displaying anything other than an all black screen. Fixable? Worth repairing?
Also I inadvertently shut off the viewfinder and, obviously, can't locate the command on the touch screen to switch to it to even view a tape that's running or what I'm recording.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@steveyv shine a light at an angle across the LCD. See if you can make out silhouettes. This will verify if it is your backlight., Most likely so you need a new LCD but if you see silhouettes etc. it is possible that you have a board error on PD-237 which is the LCD/backlight driver board. Here is how you get to the LCD
If you find that it is your backlight that is not working check CN608 on the PCD PD-237. Pin 6 should have 2.6V and pin 3 -15.5 Let us know what you find and post some good pictures of your camera if you need assistance with identification etc. Use this guide iFixitでの質問に画像を追加する方法 for that
replacement LCD's are available at ebay etc.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Steve Vale さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 28
今までの合計 920
