メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年発売 モデル番号: ONETOUCH 7024W FCC ID: RAD386
Problems Sending and Receiving Messages
When someone attempts to message me, their text comes thru multiple times (as many as 5 times). My response also comes thru multiple times. This is annoying. Please help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I can't send a text at all
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
Hi @justlittleoldme ,
Try starting the phone in safe mode and see if the problem still occurs.
If it still occurs in safe mode then try a master reset (also known as a factory restore or hard reset) and see if this resolves the problem
If it doesn't occur in safe mode then a downloaded app is the cause of the problem. The trick is to find out which one.
Try to recall when this first started happening and then check if there has been any new apps installed on the phone or if any existing downloaded apps have been updated around about the same time that it started.
If so try uninstalling it (or them if more than one) one at a time and testing the SMS function between each uninstall.
Once the problem has cleared, the last app that you uninstalled was the culprit.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Elaine さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 4,600
