メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kenmore Elite HE3は、Kenmore社製の洗濯機です。Whirlpool Duetと同一の製品です。
i'm getting a f28 error code
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 9
2 件のコメント
I am getting a f28 error as well and the washer is not spinning. I replace the CCU unit and i am still getting the code. I need some advice on what to try next.
さんによる 共有
It's the motor control unit
さんによる 共有
コメントを追加
7件の回答
ベストアンサー
The F11 and f28 codes are from a communication break in the serial link from the CCU (Central Control Unit) to the MCU (Motor Control Unit)(from the brains to the washer motor controller). Stay with me here!
There are three blue wires that go to the MCU from the CCU. Most of the problems probably occur during the final spin when the machine spins fastest and longest to extract all of the water.
Hence, the most vibrations cause the connectors to shake until there is a break in communication!
Take the top of the machine off (three #20 torx screws on the top back) to gain access into the machine. The CCU is top center back and has the spaghetti of wire going to it. You will see white wires on the far right of the CCU. Then going left they turn to black. The black set (3 wires) left of the row of white wires if for the Door Lock/Unlock. It IS a problem for the F/DL error. It is not making a good connection. Next the blue wire on the LHS of the CCU, last set (back) there are three blue wires. These 3 go to the MCU and are the serial communication lines. Tighten all these wires to make sure they are making good connections. Make sure your machine is level with all the feet on the floor. You do have a 24 month warranty one the machine so call a tech if within that period. To insure that this may be the problem, take a ride and sit on it during the final spin ;-) If it works then you know it's probably the wiring, if it doesn't buck you off first.
You really don't want to replace these parts because the MCU is $230 and the CCU is $175 -- a lot to pay for some loose wires. If you must buy parts, here they are: http://www.repairclinic.com/Shop-For-Par...
このアンサーは役に立ちましたか?
スコア 12
6 件のコメント:
+ Nice research
さんによる 共有
+Nice answer.
さんによる 共有
Thank you I'll try it
さんによる 共有
Thx, It Work , wire connection central control
さんによる 共有
I don't know what the machine described in the post is, but it bears no resemblance to my machine. The MCU board was at the front bottom left. Upon removal I discovered the circuit board had two traces burned off that go to a component that appears to be a sensor thermistor which was a shorted. I found an company that offered a board exchange a lot cheaper than a new MCU board.
さんによる 共有
1以上のコメントを表示
コメントを追加
Found this thread for you. Another owner is having the same problem. This thread teaches you how to reset your washer's memory and hopefully the error code. Good luck
http://www.applianceblog.com/mainforums/...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had the F28 error code and was able to clear it by reseating the blue wire harness from the CCU to the MCU. Thanks it works great now
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I also had the F28 error code and I finally figured out that there was a tiny amount of corrosion on the metal leads in the end of the wiring harness for the 3 blue wires that connect from the CCU to the MCU I popped the 3 blue wires wiring harness out of the MCU, sanded lightly on the metal leads in the harness, popped it back in and the washer works great again!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
What course sand paper did u use?
さんによる 共有
My Maytag 5000 must be a much earlier version. Quite different when you take the top off.
さんによる 共有
コメントを追加
Bought the dryer new seven years ago. This is the first time we had problems with it. F28 error message, front dryer panel will light up as normal, press and hold the start button but you only hear a click coming from the main control board, then nothing. Dryer never starts up. Does this happen with the corrosion problem?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Please can you help me I have the error f28 and already change the MCU and it follows the same
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The maytag 3000 washing machine is junk. I do maybe 5 loads, and then it breaks down and I have to take it apart. Getting ready to take it apart again now. I hate this piece of sh*t. I'll re-seat all the connections and maybe do 5 more loads…. if
I'm lucky.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I need help with the F28 code.
さんによる 共有
コメントを追加
回答を追加する
BECKY さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 31
過去 30 日: 186
今までの合計 98,362
