メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
Only charges when turned off.
I'm currently doing board level repair on it, replaced the transceiver for cellular service, fixed no service / service provider crash issue.
Now the issue I am having now is it only charges while off and not while it's on.
While it's off it's 0.4A.
It was working before. Charging died after transceiver repair. Replaced Tristar and now am at this issue?
Could this be replacement Tristar being faulty?
Had to rebuild audio Ic circuit as components moved around when removing the metal shield for it but fixed that okay.
Tried another charging flex and battery.
What's strange about the phone is that it will not boot up without charging cable plugged in.
So I would have to unplug battery, then plug back in and plug charging cable in for it to boot.
Seems to be no Sim card install message being spammed on this phone, probably going to give up on this one.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Hey Ben. Charging circuit issues can be a pain as there are lot's of IC's involved and some passives are spread out all over the place. You can never really be sure about Tristar so I would certainly try a new one. Tigris can also be an issue, especially if you applied a lot of heat on the radio IC's. Finally, working on the Audio IC may have impacted the PMIC, which is seriously underfilled.
However, with only 0.4A of current, check out L2300/C2300. Sometimes the carbon-like inductor separates partially from the contact point and therefore doesn't connect electrically properly and that will have a huge impact on current.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
What happens when you try a wireless charging pad?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
iPhone 6s does not support wireless charging.
Phones that support wireless charging as far as I know are iPhone 8, X and Samsung Galaxy S6 to s9.
さんによる
コメントを追加
回答を追加する
Ben さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 3
今までの合計 1,632
