メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.3GHz、2.6GHz、または2.7GHz クアッドコア Intel Core i7 プロセッサ(最大3.7GHz Turbo Boost)、6MB 共有L3キャッシュ。
Slow performance after battery replacement
I recently replaced the battery on my 15" Mid 2012 RMBP. I'd installed a clean version of High Sierra before installing the battery. Since replacing the battery, the performance fo the Mac feels a but sluggish, glitchy almost.
Here's what I did:
Tried resetting the SMC - which didn't seem to even work properly. The light on the power cord didn't blink to indicate anything had happened.
Startup progress bar also seems to stall for a noticeable 5-10 seconds now, about 3/4 of the way through. Not a killer, but a noticeable difference.
Any thoughts are appreciated.
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
4件の回答
ベストアンサー
Sometimes faulty batteries can cause Cpu throttling. I'd suggest trying unplugging the battery connector and check how the laptop behaves with Dc in only. If everything gets back to normal, it might be just a faulty battery problem.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Oh man ...
If this turned out to be a faulty battery from iFixit I might flip my top. I can’t imagine having to do that replacement again.
さんによる
コメントを追加
Got the new battery, bought from eBay.
There's no more throttling, everything running Fine.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had to remove the battery and I'm also facing the CPU Throttling.
My CPU should run at 2.3ghz, but Intel Power Gadget and Windows Task Manager shows it running at 1.1ghz.
My new battery should arrive next month, I'll post the results when I get it.
If you have any progress please share with us.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Any news?
Did it throttle under your new battery
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Zach MacDonald さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 17
今までの合計 5,392
