メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1999年に発売。初代PowerMac G3の後継機。300-450 MHz、64または128 MBのRAM、6または12 GB HDDを搭載。
Black Screen with Backtrace and Exceptions
Running OS X 10.4.11 on PowerMac G3. The system is constantly freezing and I have to restart. Often I get a black screen with a long list of backtrace and exceptions.
There is an extremely long stream of info on a black screen. Below I've listed one portion which differs from the rest:
Backtrace:
0x04DF358C
Kernel loadable modules in backtrace (with dependencies)
com.apple.driver.ndrv.ATY.Rage128.0x4df009c(1.0.2f 47)00x4def000
Exception state (sv=0x1D20C780)
PC=0x000AF354; MSR=000081030; DAR=0E02FD000; DSISR=0x42000000; LB=0x000AC134; RI=0x0000B9E0;XCP=0x0000001C (0x700 - Program)
Can anybody help me fix this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
How much RAM do you have?
さんによる
コメントを追加
1 件の回答
ベストアンサー
what you're getting is called a kernel panic. start up from your system installation disk, go to the second screen pull down menu to utilities > disk utility and select your drive on the left. run the repair till it runs clear. if this fails, reinstall your system. how much ram do you have?
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I've only got 288 MB of memory. I've avoided investing too much into the system since it has this problem. If I could just get it to stop freezing up, I might have a chance to get to know and love it. Then I might consider upgrading it.
さんによる
I don't have the original system disk that came with the system. I only have the OS X 10.4 installation disks.
さんによる
You're running on the minimum amount of RAM. Use the 10.4 disk for repairing the drive.
さんによる
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 15
今までの合計 670
