メインコンテンツにスキップ
モデル番号A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544回答 すべてを表示
Best bluetooth antenna for BCM94331PCIEBT4CAX
Goodmorning everyone,
someone would advise me which of the following two bluetooth antennas is best to use with the wifi / bluetooth (4.0) module BCM94331PCIEBT4CAX for a "MacBook Pro 17 Late 2011"?
1. K17 056-3518-A
2. 631-1570-10
I ask which of the two antennas will be able to offer greater coverage and stability of the bluetooth signal.
Thanks for the assistance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Neither of these are the correct part.
さんによる
コメントを追加
2件の回答
ベストアンサー
This is the correct part Unibody MacBook Pro 17 Airport Antenna (2011) - Apple P/N 631-0890-B. There is no options here.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You'd be better to get a new dual band usb AC wifi/bluetooth 4.0 combo dongle for a little more (prob about 50.00 and this antenna only is 27 and tax plus shipping and also used.....) and you'd have AC wifi and newer Bluetooth, but it is a usb connection instead of internal so unless you REALLY want internal only you'd gain much more with a newer AC wifi/BT 4.0 dongle for a few bucks more.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Most WiFi/Bluetooth dongles don't support MacOS so that won't really help here.
The posters focus was on Bluetooth not WiFi and he was looking for a more powerful internal antenna which doesn't exist.
さんによる
コメントを追加
回答を追加する
Alex さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 333
