メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Exynos 5プロセッサと3GBのRAMを搭載した、2014年版のGalaxy Note 10.1です。2013年10月に発売されました。
Not charging, screen flickering
Hi all, so I'm working on a friend's Note 10.1 2014 edition, and she brought it to me telling me it wasn't charging. I tried different cables, but the same thing happened - the battery symbol would show up (as drained) first, then the screen would start flickering. I left it charging for 2 hours and not even one bar would show up.
Then I found this forum with the exact same problem. https://forum.xda-developers.com/showthr...
So I looked into the USB charging port and sure enough, the pins were bent and damaged. So I ordered a new part, followed the guide here on replacing the charging cable inside. Plugged it in after the change - same exact problem.
I'm stumped and I can't find any others having this issue. What do you think? Bad motherboard?
Thanks -
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
5件の回答
Change the adaptor, and if you don't mind then the cable too
Anil
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
My sons is doing the same thing I have tried everything the screen used to go completely black if it took a knock or something but I fix that problem by taking it apart I have literally tried everything I can think of but nothing is working charged it all night just keeps flickering
さんによる
I had the same trouble. I think it is the outlet i was using. Took it to my friends house using same charging plug and cable. It charged right up. No flickering. and kept the charge all day
さんによる
No use! Doesn't work.
さんによる
コメントを追加
Factory reset it and when it asks you, volume up:continue
Volume down: cancel restart ,press volume down
it should work tell me if it does not
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thanks to everyone who helped on this. I tried these steps and none of them resolved the issue. My friend has since passed, so this is no longer an issue, but hopefully others who are experiencing this issue can be helped.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
mind is doing the same thing. I had it on while i was sleeping and it crashed. I woke up to a charging screen and the tablet unresponsive. i brought it down and stuck it on one of my computers whent e usg cable and its doing the same ting. Tryed to reset it but its not doing that either. I suspect its done, lived its life. Ill probably send it to samsung and have them do something with it. thanks for listening
さんによる
コメントを追加
Exact same issue. If at all I have to use it, then I need to have it plugged-in always like a desktop PC. Funny that the recovery mode/menu works without plugging!
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
The battery percentage always stays as 0% and charging when plugged-in and the tablet shuts down immediately when unplugged.
さんによる
I just tried switching to a different outlet like the person above recommended, and that did the trick. 😎 Thanks!!
さんによる
Dear George mixco . I'm sorry for your loss. I'm familiar with loss of loved ones . My condolences . God bless
さんによる
コメントを追加
If your screen is still flickering, try adjusting your brightness settings, and disabling the adaptive brightness feature. Corrupted data in the system on your device can sometimes cause the screen to flicker. Clear the cache on your device, then check if the flickering continues.
Greetings,
Peter
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
George Mixco さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 34
今までの合計 36,403
