メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
checking device fail leads to bios password
hello,
sooo, I tried changing the HDD in my Ideapad 500-15isk model no 80nt a while back due to the old drive failing and had no luck getting through the password barrier to do a force boot, i tried both a formatted HDD and a HDD with windows installed both to no avail.
i have tried taking both the battery out and the cmos battery and leaving it for a while. this did nothing so im out of ideas.
anybody got any solutions for this problem?
thanks in advance
tom
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
This may help
https://www.youtube.com/watch?v=KmsGG6_E...
If not then you can always short out the Eeprom chip
Also how long did you remove the cmos battery, 20 minutes to half an hour are necessary to clear the bios
Hope this helps
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thank you so so much, sorry about the late reply but i gave up on the laptop until today, i tried the link above and unfortunately that was of no use however tricking the system by shorting the Eeprom chip did the job perfectly, thanks again Jim. Top marks!
さんによる
コメントを追加
回答を追加する
thomas plant (tomplant56) さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 14
今までの合計 1,042
