メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Headphone and ear speaker not working after battery replacement
I decided to dive inside my iphone after my battery became pretty much dead. Got a new battery from scandiTech and did the replacement myself, everything seemed fine untill I tried to make a call, i couldn’t hear a thing from the ear speaker so i thought i had broken the ear speaker’s flex cable but upon using a headphone which too didn’t produce any sound I concluded that the problem is not from the ear speaker cable, the control buttons on the headphone works normal. The music speaker works fine too. Please can anyone help, i’m not ready to get a new phone.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Unplug the battery and reseat the screen and charging port ribbon cables.
I can't really see how those go faulty if you disconnected the screen after unplugging the battery during battery replacement.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Im not sure about iphone 6 but i know one iphone 5S that did get reversed problem, no music sound but ear speaker worked.
A small metal part did get bended when the battery connector was set down .
remove the battery connector and the lightning connector and around that there is smal protecting tape, remove that and look around the battery connector if you see any metal parts or components that are bended/moved or hits any other component.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
here’s the problem 90% of the time. Someone tore this cable and refused to take responsibility. I replaced it for them. (See photo)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Speedy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 22
今までの合計 2,530
