メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung社製ノートパソコンのサポートおよび修理情報です。
Laptop Cannot Boot, Preparing Automatic Repairs - Fails
Please I need your help. Anytime i on my laptop, it tells me preparing automatic repair then tells me diagnosing your PC. After that, it says automatic repair couldn't repair your PC. Log file: C:\windows\System32\Logfiles\Srt\SrtTrail.txt.
Please what should I do now?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
6 件のコメント
Hi emmanuel kese
Normally for this kind of issues, I will run HDD / SSD Diagnostic to check for any possible issues first.
If data is important, I would recommend you to use a "Live CD" like linux, WinPE to copy all the files out.
If your HDD has issues, you will need to either send in for service if it is under warranty, else you will need to get it replaced, then you can consider on SSD drives.
Else if the HDD / SSD passed the diagnostic test, most probably, the operating system is corrupted.
さんによる
Okay thanks for your help
さんによる
Similar problem on Acer E1-510 running Windows10 vers1803 mainly occurs after Windows updates. After restart my laptop gets stuck in "Acer explore beyond limits" screen. After Hard shutdown(hold start button till laptop turns off), then start(push start button) the laptop gets stuck in "preparing automatic repair" screen. More hard shutdowns and starts just alternate between these 2 stuck screens. The laptop does not display a repair option screen as some sites suggest will happen after the third restart.
However, if I unplug the mouse(& any other USB connected devices) & the wire to the modem, then next Start the laptop works!
Maybe this is a signal my computer is about to expire, but the method solved the problem for me the last 3 times it occurred.
さんによる
My laptop still says preparing automatic repair how to get rid of it please
さんによる
I’m stuck in the same loop nothing has worked
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
Hi,
Here is a link that may be of some help in fixing your SrtTrail.txt problem
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
回答を追加する
emmanuel kese さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 15
過去 30 日: 35
今までの合計 16,013
