メインコンテンツにスキップ
モデル番号A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544回答 すべてを表示
Way to fix a loose Headphone Jack
Hi, I've bought a Sennheiser HD-25 headphone, I've had this phone before and I know that it's jack has a very nice and tight fit. Although using it with my MBP 17" is a pain. With the slightest movement, the jack gets disconnected. Any way to fix this?
I had another MBP the very same model and the headphone jack was fine.
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Sadly the jack is part of the logic board are well mounted! You would need to replace the logic board.
How about getting a USB DAC unit to plug your headphones into, here's one unit: Audioquest -Dragonfly
Update (03/13/2018)
Here's a view of the logic board where you can see the input & headphone jacks:
I was able to use a jack from a junker to replace mine. Apple uses a custom part and its just not available as a spare. This is also not an easy job!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for your answer Dan,
I already use (most of the time) a dedicated audio intercafe, in this case an Apogee Duet FW. I monitor via speakers and headphones thru them. But sometimes I’m not carrying it around, so for the convenience sake I would like just to plug my headphones in the MBP’s jack.
Also I’m very fond of the DAC that you suggested me. Unfortunately where I live those are quite expensive!
さんによる
Sorry I can't offer you a cheaper solution ;-{
Replacing the logic board will be much more costly.
さんによる
コメントを追加
回答を追加する
Lucas Parisi Santos Freitas さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 1,447
