メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2008年に登場したThinkPad。低コストのノートパソコンを必要としつつも、主要な機能には妥協できない中小企業市場をターゲットとしたマシン。
Supervisor Password Thinkpad SL500
Hi there,
I have a Thinkpad SL500, with a supervisor Password, which I do not know. Does anyone have a clue how I get rid of it. As far as I have read, theres no eeprom on this motherboard which I could short to get rid of it. There is no power on or Harddisk password inserted. Removing the bios battery does not help either now it just ask every startup to correct time and date.
Greets Simon
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
My SL 500 too is lock and Iam experiencing the same problem
さんによる 共有
コメントを追加
2件の回答
最も参考になった回答
You'll find a couple of liks to recovery password generators at the bottom of this page:
https://therestartproject.org/wiki/UEFI_...
But according to the Service Manual there is no procedure for resetting the Supervisor Password. You have to replace the motherboard. If you can find and replace the BIOS chip that might be a last resort solution but you’d almost certainly have to source one from another laptop of the same model, in which case you’d be better off swapping the entire motherboard.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Lenovo is not suported, I have an error code, but it is a code you can lookup in the manual of the SL500.
さんによる 共有
Also cmospwd does not work
さんによる 共有
コメントを追加
Probably not the answer your looking for but if you have a heatgun/good soldering skills you could try replacing the bios chip: https://www.ebay.com/itm/BIOS-CHIP-LENOV...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I would rather perfer a solution which does not include replacing parts on the mothermoard. Although if there is a solution like with most other ThinkPads where there is to analize a Signal or short some contacts this would be ok.
さんによる 共有
コメントを追加
回答を追加する
Siki さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 23
今までの合計 1,105
