メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
Touch screen crazy behavior
Hello , I´ve a serious problem with my Iphone X , the tactile interface creates random clicks on display. For example if I manage to open the calculator some numbers are not working and in other moments start to type ramdom numbers 88789383... and do on. I´m not sure if the problem would be fixed replacing the complete display assembly or I need to replace other parts.
Regards, Patricio.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
3件の回答
ベストアンサー
The display is the likely issue here however given that your phone is surely still under warranty, I would suggest you have it replaced by Apple.
If your phone shows any signs of physical damage, they may refuse to to change the screen in which case a reputable third party repair shop can help you out or you can try it yourself.
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
I'm having. the same problem and asked for a replacement and is doing the same thing, I can only think is that your part is not fully comparable with my phone I'm going to ask for a refund .
さんによる
コメントを追加
My phone had become very glitchy. It would type random numbers or change screens on its own or wouldn’t recognize a touch. After calling Apple three times and going to the Apple store twice, they determined I needed a new display. Since it was still under warranty, there was no charge. So far, problems been solved.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I've got an Iphone X, the screen was going crazy opening random apps, impossible to type, etc. I was ready to smash it. I went into display settings and turned off True Tone-it seems to be fixed!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Why would of that fixed it?
Your only changing the colour of the screen
さんによる
コメントを追加
回答を追加する
patriciogreco さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 23
今までの合計 66,908
