メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
7.9インチディスプレイ / モデル番号 A1454 / ブラック、ホワイトのカラーオプション / 発売日は2012年10月23日 / 16, 32もしくは64 GB容量
Turns off randomly after drop
After I dropped the iPad (it cracked very badly) on concrete from a table the device seemed to be fine. It shut off after about 30 seconds of the drop. Then it said low battery. Then it proceeded to boot normaly again. Now it keeps cycling like this! When plugged in it lasts a bit longer but still does not stay on. Need this resolved soon as I am going on a trip soon and would love to use this on the airplane. Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Seeing as how the battery connection does not seem to be the issue, I suspect that the logic board may have been damaged from the drop; most likely a cracked solder connection somewhere. This will require that it be looked at by an experienced micro-solderer.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Ehhhh... what chips would cause this kind of issue?
さんによる
It could be any one of a number of critical IC's, it hard to say based on it just being dropped. It would have to be properly diagnosed to know for certain. IC's like Tristar, PMIC, Baseband, CPU, NAND etc. would be likely candidates but even something less critical can cause a cascade of issues.
さんによる
コメントを追加
Hi
Look like the battery is disconnected not completely but move from the connecting place u need some one how know how to disassemble the ipad and reconnecting the battery properly
Good luck
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
battery replacement guide: iPad Mini GSMのバッテリー交換
さんによる
Hey sam! I have already disassembled the iPad and re-seated the connector. Nothing has changed. thanks!
さんによる
コメントを追加
回答を追加する
Ethan Leroux さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 26
今までの合計 562
