Broken wire - hyper x cloud 2
Hello, the tip of my wire at the jack is broken. Is there anyway that I can fix it, or is there anywhere I can get it repaired? Thanks.
My headset had the same issue. I ended up replacing the connector. If you snip off the connector and solder a new one on that should solve the issue. Just make sure you solder the wires to the same spot they were before. Here is a good guide: https://www.youtube.com/watch?time_conti...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 4,343
can you post up a picture? thats a pretty cague description of what is wrong lol
Logixal さんによる
