メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Stylo 2(モデル番号:LS775)はStyloシリーズの第2世代モデルで、LGによって製造され、2016年4月に発売されました。
Sound is not working
I only have sound when using headphones. How do I get my speaker to work?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント
I have to same problem it say my headphones are in but they are not
さんによる 共有
It shows headset logo on screen and sound is not working
さんによる 共有
I am having the same problem with my LG Q Stylo+. If anyine has anyrhing to help please contact me at aedanouellette@gmail.com
さんによる 共有
コメントを追加
5件の回答
最も参考になった回答
Tried various fixes I found online for the same problem with my LG Stylo2. This is what worked for me....Remove the back cover of your phone and push on the speaker (left bottom) a few times. All of a sudden I have sound again. Loose wire likely cause inside speaker!! Hope this works for you.
このアンサーは役に立ちましたか?
スコア 7
9 件のコメント:
Thank you!!... I tried all sorts of things to get my speaker working again!... I almost did a factory reset on it.. Who would've thought something so simple would work! Lol.... Thank you again for your advice!
さんによる 共有
Thank you! This worked.
さんによる 共有
I am so glad. Did not know if this would last but 4 months later and mine is still working with no problems. Glad I could help.
さんによる 共有
It worked for me too!!!
さんによる 共有
and anotha one!!!!
さんによる 共有
4件以上のコメントを表示
コメントを追加
You got to take the back off and screws out take off souronding plastic molding there is 2 pins connected on the speakers itself they must be touching the tape or ribbon perfectly or you will not get sound go to YouTube for video on how to take phone apart properly
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Had the same issue took it all apart & put it back nothing, sprayed the contact cleaner ,pulled the speaker out tested it outside it was good, then i saw where the speaker sits if you push the cover you'll hear a click that is the notch that pushes the cover & makes the contact.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
thanks so much i try this way my problem was resorve .
さんによる 共有
The push and click worrrrrked! Thank you so much!
さんによる 共有
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Pushing of speaker repeatedly from left to right or from right to left by removing just back cover
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Geneva Campbell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 23
今までの合計 13,182
