メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Harley-Davidson Sportsterモーターサイクルの1986年モデルから最新モデルまでの修理ガイドです。
Strange sound from my engine
Hi guys, i bought a sportster 883 r two months ago and i knew from the mecanic that the guy i bought it from, had a failure in the oil pump and he drove 15 miles, the mecanic said he changed the pump and one from piston head. But a tic tic sound is coming from the engine and the sound becomes higher when i drive long distance, anyone can help me what this sound may be???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
I recently figured a new problem every 40 miles my rear spark plug is fouling is it related to the ticking sound??
さんによる
Quite possible, is it oil fouling? If so your lifters may need adjusting, and if they are auto adjusting, you may need to replace either your chain/belt, slipper/tensioners. Does it blow a bit of smoke on start up, or when taking off from traffic lights. These are indications of valve stem seals and or valve adjustment.
さんによる
Yes, it is blowing smoke on startup.
さんによる
コメントを追加
1 件の回答
Tic ticking sounds are usually lifters. Or noisy valve train. I'd personally take it to another mechanic, don't tell him the story. See what that guys says it is.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It could be anything really, as the engine may need a full rebuild.
さんによる
コメントを追加
回答を追加する
Johnny Chebel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 20
過去 30 日: 35
今までの合計 1,292
