メインコンテンツにスキップ
The Logitech UE Boom 2 is a waterproof, portable Bluetooth speaker known for its 360 degree sound. The Boom 2 comes in a multitude of vibrant colors and patterns.
20回答 すべてを表示
Sound quality is poor with PC
My Ue boom. works fine when connected to a phone, but when i connect it to my PC the audio coming out is absolutely terrible. Does anyone know a way to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 11
16 件のコメント
How are you connecting it? Bluetooth or cable?
さんによる
It wasn't charging, so by bluetooth
さんによる
Hi,
What is the make and model number of your PC?
What OS is installed?
さんによる
My PC is a dell XPS 15 and is windows 10.1 64bit
さんによる
I have the same issue with my Asus laptop (running Windows 10, 64bit)
さんによる
11件以上のコメントを表示
コメントを追加
8件の回答
最も参考になった回答
What solved this for me:
1. Connect the speaker and choose the MEGA BOOM Stereo device. Often you will get no sound when you do this at first.
2. Once selected turn the speaker off and back on again and when it auto reconnects it should connect the speaker device and work correctly.
If the above didn’t work try this as this worked for me for one of my machines.
1. Connect the speaker.
2. Go to Control Panel\All Control Panel Items\Devices and Printers and remove the “dongle”
3. Go to Control Panel\All Control Panel Items\Devices and Printers > right click on the MEGABOOM headphone icon and choose properties > Services > uncheck “Handsfree Telephony
4. Set your sound output to MEGA BOOM Stereo device, which will produce no sound.
5. Restart your MEGABOOM, once reconnected it will work correctly.
I have this issue on Windows 10 as well. There has to be something strange with the hardware being used in the mega boom. Windows picks up 3 separate devices when I connect to mine, a dongle which the driver will not work for, the hands-free headset, and the speaker. The handsfree headset is locked in at 16bit sound and sounds terrible. The setting is also locked out in sound manager you can’t change the bit rate for the headset device. I tried everything from getting drivers to work with the “dongle” that is seen to disabling things in the device manager, updating bluetooth drivers, etc.
このアンサーは役に立ちましたか?
スコア 12
9 件のコメント:
Thanks!! This helped
さんによる
Thanks for the answer man. Spent hours looking for a solution! Had to create an account just to say thank YOU !!!!
さんによる
simply changing the output also didn't work for me with my Boom 2, but your solution did! thank you!
さんによる
Thank you! The uncheck "handsfree telephony" works for me
さんによる
The on/off trick solved it for me as well. Thank you, Seth! I also made this account just to be able to say thx. Have a nice day
さんによる
4件以上のコメントを表示
コメントを追加
I have the same problem with my UE Boom 2 when listening on my MacBook Pro. Just fixed it by changing the Sound Input to Internal Microphone instead of Boom and keep UE Boom on Sound Output only.
Hope it helps.
Cheers,
C
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
This is the one!!! All macbook users this is the answer!!!!
さんによる
This fixed it! Thanks!!!!
さんによる
Holy cow this was driving me nuts!!! THIS IS THE ANSWER IF YOU HAVE A MACBOOK!! I was trying to work out how the Boom got assigned to audio input - I reckon it was Skype when I used it earlier today.
さんによる
Yay!!!! Thank youuuuuu <3
さんによる
コメントを追加
I would suggest trying this guide for fixing Bluetooth audio quality on windows: https://www.youtube.com/watch?v=55yn-zF_...
このアンサーは役に立ちましたか?
スコア 3
8 件のコメント:
Didn't fix it sound quality is still poor, and i cannot uncheck the handsfree telephony because the ue boom will disconnect
さんによる
Then I would keep my eye out for a firmware update that may fix the issue.
さんによる
You sir are a lifesaver - I was getting very frustrated with the sound quality of a ue megaboom but your suggestion fixed it. Thank you so much!!!!
さんによる
peter eddleston, what was the suggestion that solved your problem, Pleeaaase!
さんによる
I have the same problem as Emerson "
Didn't fix it sound quality is still poor, and i cannot uncheck the handsfree telephony because the ue boom will disconnect"
さんによる
3件以上のコメントを表示
コメントを追加
Go to Control panel > Devices & Printers > Select your device > Properties > Services > Uncheck Handsfree telephony
Hope this helps
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
I'm not getting any sound from the Stereo one but I getting bad quality sound from Handsfree... I don't know how to fix the problem to get sound trough Stereo? any ideas why?
さんによる
コメントを追加
You need to make sure the sound output is set-up as "UE Boom 2 Stereo" NOT "UE boom 2 Hands Free"
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
"UE Boom 2 Stereo" produces no sound at all. :( The other one bad quality.
さんによる
Yay! It worked! Thanx heaps!
さんによる
コメントを追加
Might be there is a problem in the port of your computer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Changing settings from UE handsfree to UE stereo fixed the problem. Thanx heaps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
On my PC (XPS 15 running Windows 10), I was able to resolve the problem by going into Sound>Manage Sound Devices. There I found two UE BOOMs: headphones and headset. I disabled headset and then selected “Headphones UE BOOM 2 Stereo” in the volume pop-up menu and it worked a charm. Hopefully this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Emerson_Wilmot さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 26
今までの合計 25,950
