メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canonの「スーパーズーム」搭載コンパクトデジタルカメラ設計における第3世代モデル。2006年2月に発売。
LCD screen cracked. Replacement process?
The screen on my camera is cracked.
The screen will not come on at all right now.
I would like to replace it.
I found the blow-up diagrams but is there a correct process?
Do I also need to replace the Back Light Unit?
Thank you in advance for your help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@nanaburt yes there is and all you have to do follow it in sequence as outlined in this document S3-Disassembly.pdf
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Thank You oldturkey03. I have the diagrams, Can I start at the point of taking the LCD cover off (after removing the battery) or do I have to remove the screen at the hinge before taking the cover apart?
さんによる 共有
... also ... are there any precautions on where I should NOT touch as I remove the PBC Assembly as I need to re-use the current one if possible.
さんによる 共有
@nanaburt this does look complex but at this point I'd follow the individual steps as they are outlined. Stay away from the flash cpacitor since it does pack a punch. You should always discharge that one before working on a camera. I do try to not touch all over the pcb but there is only a small chance to either shorten things out or cause damage due to static electricity.
さんによる 共有
コメントを追加
回答を追加する
Gale さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 22
今までの合計 618
