cracked look in screen
my laptop has a layer that looks cracked not top layer it was leaned on
So your glass is okay but your LCD is cracked? Time to get a new display they are relative inexpensive http://www.lcdscreen.com/ppc-series-acer...
このアンサーは役に立ちましたか?
If you are not planning on replacing an LCD connect an external monitor using a VGA cable for output or if your TV has a VGA connector then you can even get the output on your TV.
You can buy a replacement LCD from eBay and take it to a local electrician and have it replaced for you
Good Luck.
このアンサーは役に立ちましたか?
Hopefully the OP fixed it within the last 2 years ;-)
過去 24時間: 2
過去 7 日: 4
過去 30 日: 16
今までの合計 2,109
