メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPod Classic 第6世代。モデル番号はA1238 / 80、120、160 GBハードドライブ / ブラックもしくはシルバーメタルフロント
Dead iPod- NOT the battery
iPod won't turn on, regardless of whether or not it is plugged into anything. The battery life is still in really good shape and was fully charged at the time it stopped working. Had walked to work with it on, left it in pocket, took off coat, then took out iPod to use in an audio system and it wouldn't turn on. Seems improbable it could randomly die in 5 minutes...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 14
4 件のコメント
It worked, oldturkey. Thank you for protecting me from my own karma.
さんによる
Thank you for accepting my answer. Wishing you the best of luck and keep on jamming:-)
さんによる
Thank You It worked never thought of the on off button i tried everything else
Thanks Again
さんによる
Your instructions worked miraculously! I really thought I had lost it (and all my recordings) forever. THANK YOU!
さんによる
コメントを追加
2件の回答
ベストアンサー
Yes, they can die from one minute to the next :-) Try to reset your iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
What happens when you plug it into your computer? If this does not work, you may have to take a closer look at it. Let us know how it is going. Good Luck
このアンサーは役に立ちましたか?
スコア 20
32 件のコメント:
Had same problem. Solution worked. Thank you very much.
さんによる
awesome...problem solved...thanks
さんによる
Nice. Thank you. Problem solved!
さんによる
Thanks so much! worked perfectly
さんによる
@Matt Tierney, you are welcome :)
さんによる
27件以上のコメントを表示
コメントを追加
will I lose my tunes if I replace a dead hard drive on my apple iPod 5th generation
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yea as this is where the "Tunes" are kept.
さんによる
コメントを追加
回答を追加する
Danielle さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 16
過去 30 日: 63
今までの合計 50,343
