メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年後半に発売されたAsus X55Cは、画面解像度1366x768の15インチラップトップです。Intelプロセッサを搭載し、Intelの統合グラフィックスを使用しています。
Computer just blacked out.
Not sure if it's connected, but my sister just put a connected Micro USB into the USB port of this PC that I've had for quite a while. At that moment it just went out, no indication of life, no lights turning on. Checked that the charger is just fine. I'm not sure if connecting the Micro USB trough the wrong port to the computer itself can break it, but it seems the only logical case. I'd understand if it went out of old age, but it just happened instantly. What could have happened here? Is it the USB or possibly something else?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi,
The metal jacket around the micro USB may have shorted out the +5VDC power supply to the USB port and also it may have affected the USB controller by connecting +5V to it as well on the USB data lines. I don't know why it would affect the rest of the laptop and not only the USB ports and USB controller though.
Perhaps the whole +5V supply in the laptop (derived from the battery (or the adapter) may have been affected.
The laptop has various power supply rails of different voltages in it.
You may have to open it up and check if you can see any obvious signs of damage. Hopefully perhaps only an onboard fuse (or fusible link) may have been blown.
If this is the case once the +5V is restored it may work again, but possibly not the USB ports as no doubt the USB controller would have been fried.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Was it just connected to something or was it like some sort of flash drive?
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
The USB was connected to the computer and the Micro USB was put into another USB port.
さんによる 共有
Have you tried charging the battery for ~24 hours or so?
さんによる 共有
Yes, still no signs.
さんによる 共有
So you plugged the computer into itself with a USB cable?
さんによる 共有
With a Micro USB, it wasn't even a compatible port.
さんによる 共有
コメントを追加
回答を追加する
Julijus J (Laujas) さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 12
過去 30 日: 25
今までの合計 517
