メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Appleが製造したiMacシリーズの最初のパーソナルコンピュータモデル。iMac G3は1998年から2003年の間に製造されました。
Glow or light up
I've been given an iMac G3 which is almost perfect. I've put OS 9.2.3 on it which runs fine.
The only problem is the blue shell does not light up or glow?
Searching the Web I came across a statement that there was a bulb somewhere near the round plastic handle but I can't see one.
Anyone know how to get it glowing again please?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Thanks for your help - I must have believed some hype Apple Advert I saw in 1998!
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hello,
I was looking up teardown of this particular model and I can't see anywhere the above mentioned light.
If you can provide me the link where you found that it was glowing at some point there is always a way to fix by the way could be steep because of the age of the machine.
You can look up how hard it's even to open this thing up:
https://www.youtube.com/watch?v=j-w-3LZi...
このアンサーは役に立ちましたか?
スコア 3
8 件のコメント:
That's modding, the MAC didn't have that built in.
さんによる
You can send the MAC to experienced electrician/computer scientist if you want that the light is powered from inside from the computer. If you want to do it yourself without knowledge for computer science and electricity you can drill(somehow make) the hole and push the led strip inside powering it from outside with a cable.
さんによる
If this answered you'r question please rate it and mark it solved so others looking for this subject know what's going on. Thank you.
さんによる
I thought they were sold in a range of different colours and lit or glowed from new not that they had to be modified?
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Denny Tuckerman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 18
今までの合計 713
