メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
MANUAL for 5s reassembly
Where is the active, valid link for the Instruction Manual for the REASSEMBLY of the iPhone 5s? It was available on 4th January, now the link states"invalid link".
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
1件のコメント
OK. This is not cool. Reassembly is not quite so simple as just reversing the steps and I really didn't appreciate it that the video is so reassuring that there is another video out there that shows the reassembly process. I had a minor battery issue with my 5s, now I haven't got a phone at all after being just as careful and anal retentive as possible in following your instructions - minus of course, the reassembly video you said existed.
Whoof. It's hard to understand why you guys haven't been sued right out of business. Iphones are expensive. Before I met you guys - I had one that worked. Now... I have a paperweight?
さんによる
コメントを追加
2件の回答
最も参考になった回答
I've personally used the battery replacement guide more than once to disassemble and reassemble an iPhone 5s.
iPhone 5s のバッテリーの交換方法
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
@celeste15 not sure where you found the "Manual for the REASSEMBLY of the iPhone 5s". Post your link with your question so we can at least check for you. If you follow these guides iPhone 5s in reverse steps, you will get it accomplished as well.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
JANICE CASEY さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 7
今までの合計 1,664
