MANUAL for 5s reassembly
Where is the active, valid link for the Instruction Manual for the REASSEMBLY of the iPhone 5s? It was available on 4th January, now the link states"invalid link".
I've personally used the battery replacement guide more than once to disassemble and reassemble an iPhone 5s.
このアンサーは役に立ちましたか?
@celeste15 not sure where you found the "Manual for the REASSEMBLY of the iPhone 5s". Post your link with your question so we can at least check for you. If you follow these guides iPhone 5s in reverse steps, you will get it accomplished as well.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 1,660
1件のコメント
OK. This is not cool. Reassembly is not quite so simple as just reversing the steps and I really didn't appreciate it that the video is so reassuring that there is another video out there that shows the reassembly process. I had a minor battery issue with my 5s, now I haven't got a phone at all after being just as careful and anal retentive as possible in following your instructions - minus of course, the reassembly video you said existed.
Whoof. It's hard to understand why you guys haven't been sued right out of business. Iphones are expensive. Before I met you guys - I had one that worked. Now... I have a paperweight?
Christy Hemenway さんによる
