メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
世界中のオフィスで一般的に見られるLenovoのノートパソコン。
Laptop to desktop project
I've got a lenovo thinkpad t410 with a serious overheating problem. I'd like to turn it into a custom desktop for a fun project. Instead of using the included fan, I want to use a large aluminum heat sink from an old desktop, with another fan directed up through it. However, the thinkpad will shut down without the original fan and heat sink in it's proper place. Does anyone know of a way to disable this function to allow me to proceed with this project?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
@anathem0 not quite sure what your setup currently looks like., You should consider posting plenty of images so we can see what you see. iFixitでの質問に画像を追加する方法 How do you have the replacement heatsink and fan connected? Any chance you could connect that fan to the T410 motherboard?
さんによる
I seem to have located the issue. I believe that the problem was that heat was not being drawn away from the chips fast enough and the system detected this and shut down. A simple application of some thermal paste seems to have fixed the problem. In addition to the aluminum heat sink and the correct application of thermal paste, I will be re-utilizing the original fan to circulate air through the build. When it's done, I'll post some pictures!
さんによる
コメントを追加
1 件の回答
ベストアンサー
It may be that it's shutting down as a precautionary measure having detected that the original fan isn't connected. If you remove the fan from the original heat sink and cooling fins you can maybe plug it in just as an experiment.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Samuel Bennett さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 12
今までの合計 603
